| Welcome to the Kawasaki Owners Club 21,000 + Members and growing. CLICK here to Join Kawasaki Owners Club! If you're already a member please log in to your account to access all of our features: |
| Front Brake Trouble ZX6 99G2 | |
| Topic Started: Jan 10 2012, 11:21 PM (154 Views) | |
| cpt-fisher | Jan 10 2012, 11:21 PM Post #1 |
Biker
Does anyone else have brake trouble with there yaki ZX6 G2 ? Heavy Vibrations and very spungy brakes! ?? Help |
| zx6junkie | Jan 17 2012, 10:00 PM Post #2 |
Hi have you made sure the discs arent warped? Take the calipers off and give them a really good clean make the piston comes out and give them a good clean. Bleed them through a couple of times. If all that doesnt work the calipers might need a total overhall and some new braded hoses should work. |
| MUD | Jan 21 2012, 09:07 AM Post #3 |
MUD
At a rough guess i would say the slider pins in the rubber bush's are siezed and need cleening and greasing |
| Teesside Bikers | |
| scoop | Jan 26 2012, 09:53 PM Post #4 |
I had the same on my zx6 f1. I put new piston in master cylinder, but only a little better. But was told to change the steel lines, with splitter, with twin lines from master direct to callipers. A lot better. It's always better when I leave the bike in the garage and use a cable tie to hold the front brake lever in to let it bleed itself. Works every time. |
12:42 PM May 18
