New Posts
You're currently viewing our forum as a guest. This means you are limited to certain areas of the board and there are some features you can't use. If you join Kawasaki Owners Club, you'll be able to access member-only sections, and use many member-only features such as customizing your profile, sending personal messages, and voting in polls. Registration is simple, fast, and completely free.
Join Kawasaki Owners Club!
lookin for; zxr 750 h2 manual
Topic Started: Nov 5 2009, 10:47 AM (245 Views)
rawbase
hi there im lokkin for a zxr 750 h2 workshop manual as i need to reset the ignition timin also need to adjust the mixture as ive had to move some of the air box to fit a ducati 916 sub frame and seat unit would also like to check the valve clearances thanks rawbase wheelie :kawas
viperboy
ignition timing cant be reset its fixed
air fuel mix wont need changin cos ys altered air box but its about 2 1/2 turns out /use a colour tune plug if ya want it spot on but to be honest 2 1/2 is near enough an wont make any diff
if it aint noisy a wunt even bother wi valve clearance as they are bucket an shims an a right "oops" of a job to do less it is noisy then chances are its prob cam chain tensioner anyway, much easy to do
hope this helps
« Previous Topic · Tech Manuals · Next Topic »
Copyright © All rights reserved 1999-2010 www.kawasakiownersclub.com
