| Welcome to the Kawasaki Owners Club. We hope you enjoy your visit. You're currently viewing our forum as a guest. This means you are limited to certain areas of the board and there are some features you can't use. If you join Kawasaki Owners Club, you'll be able to access member-only sections, and use many member-only features such as customizing your profile, sending personal messages, and voting in polls. Registration is simple, fast, and completely free. Join Kawasaki Owners Club! If you're already a member please log in to your account to access all of our features: |
| blowing fuses; KZ400 74 wiring | |
| Topic Started: Nov 2 2009, 02:06 AM (184 Views) | |
| jlalonde | Nov 2 2009, 02:06 AM Post #1 |
changed some bad wire to the rectifier now every time key is turned on it blows a fuse. Any suggestions on where to start? |
| Kawasakifreak | Nov 2 2009, 09:28 PM Post #2 |
300+
Hi jlalonde, Is the engine running when the fuses blow ? Kawasakifreak |
| Kawasakifreak - the older I get the faster I was. | |
| jlalonde | Nov 2 2009, 09:30 PM Post #3 |
No. I've got no power at all. |
| andy-750 | Nov 3 2009, 08:44 PM Post #4 |
you have a short circuit somewhere , start looking at the wires you changed first
| faster in black | |
| jlalonde | Nov 4 2009, 12:49 PM Post #5 |
I'll keep looking. I have recently had the headlight off and installed an ignition switch. I may have to take a closer look at that again. |
| tim hall | Nov 5 2009, 12:09 AM Post #6 |
You've definately got a short somewhere. Check the wiring behind the headlight, it's possible you've connected the switch wrongly. If that's OK, leave the fuse out, beg borrow or steal a multimeter. This should confirm a short. Now try disconnecting wires until short disapears. Easy, :wacko: |
| « Previous Topic · Kawasaki Streetbikes. · Next Topic » |
1:35 PM Sep 8
