| Welcome to the Kawasaki Owners Club We specialise in technical information & assistance for anyone seeking advice for all Kawasaki motorcycles 23,000 + Members. This site is ad free to members. CLICK here to Join Kawasaki Owners Club! If you're already a member please log in to your account to access all of our forums: |
| KLX 250; Sticky throttle | |
| Topic Started: May 27 2006, 03:24 AM (1,559 Views) | |
| Juststartin | May 27 2006, 03:24 AM Post #1 |
I have a 2006 KLX. It has only done 1300k's and recently the thottle has started to stick on occasion. Any ideas on how to remedy this would be appreciated.
| dogdragon | May 27 2006, 10:49 AM Post #2 |
Hi Sticky throttle eh? OK, Firstly check the throttle cable(s) to make they aren't snagging between tank and frame. . If neccessary remove the cable and oil it or replace it if the cable(s) are frayed, in the handgrip and the carb ends, or badly kinked between handle bars and carb. If it persists, thake out the slider from the carb and check and clean, then replace it into position. Do not move or change the brass screw where the cable runs through, at the top of the carb. and note the needle setting for if you have do the cable. any more probs, let us know Si ![]()
| « Previous Topic · Kawasaki Dual-Purpose/Offroaders · Next Topic » |
1:48 PM May 22
